  > Power Amp SB-301
브랜드 : Plinius
가격 : 11,000,000원
등록일자 : 2011.02.16
조회수 : 1,253
  • Power : 310 watts continuous per channel into 8 ohms.
  •                 Both channels driven from 20Hz to 20kHz
  • Frequency Response: 20Hz to 20kHz ±0.2dB. -3dB at 70kHz
  • Distortion: Typically <0.05% THD at rated power. 0.1% THD and IM worst case prior to clipping
  • Current Output: 100A short duration peak per channel. Fuse protected
  • Rise Time: Typically 5µs
  • Hum & Noise: 100dB below rated output 20Hz to 20kHz A-weighted
  • Input Impedance: 47,000 ohms
  • Gain on RCA Inputs: 32dB
  • Gain on Balanced Inputs: 38dB
  • Dimensions: Height 220mm (8.75"), Width 500mm (19.75"), Depth 455mm (18")
  • Weight : 38kg (83lb)
