  > Speaker P3ESR
브랜드 : Harbeth
가격 : 2,400,000원
등록일자 : 2011.03.01
조회수 : 1,265
변환기 시스템 2-way: Harbeth 110mm RADIAL2™ mid/bass; 19mm Ferro-cooled tweeter with HexGrille.
응답주파수            75Hz - 20kHz +/-3dB free space, 1m with grille on with smooth off-axis response.
임피던스 6 ohms - easy to drive.
감광도 83.5db/1W/1m
권장앰프출력 Works with a wide range of amplifiers, ideally from 15W/channel.
파워 핸들링 50W programme
커넥터 Two 4mm gold-plated binding posts for wires or plugs
치수 (hxwxd) 306 x 189 x 202 mm (inl. grille and terminals)
마감재질 Cherry, black ash, maple, rosewood, eucalyptus.
최대필요공간 Ideally > 0.30m from rear wall
필요스탠드 Typically 24+ inches
중량 6.3kg each
