  > Speaker Super HL5
브랜드 : Harbeth
가격 : 3,980,000원
등록일자 : 2011.03.01
조회수 : 1,401
 제품사양(Specification)
변환기시스템     3-way reflex 200mm RADIAL™ bass/mid, 25mm tweeter, and 20mm SuperTweeter.
응답주파수.        40Hz - 24kHz +/-3dB, free space, 1m with grille on, smooth off-axis response.
임피던스 6 ohms easy to drive.
감광도 86db/1W/1m
권장앰프출력  25 - 150W.
파워 핸들링 150W programme
커넥터 Four 4mm gold-plated binding posts for wires or plugs (biwireable)
치수 (hxwxd) 638 x 322 x 300mm
마감재질 벚꽃, 유칼리 나무, 자단.
필요공간 Overall response optimised for use away from walls.
스탠드 To bring ears level with tweeters: typically 16-20 inches.
중량 17.2kg each
