> Speaker |
Monitor 40.1 domestic |
브랜드 |
Harbeth |
가격 |
13,900,000원 |
지점구분 |
서초 |
등록일자 |
2011.03.01 |
조회수 |
1,398 |
제품사양(Specification)
변환기시스템 |
Three-way reflex - Harbeth 300mm bass unit, 200mm RADIAL2™ midrange and 25mm tweeter with HexGrille. |
| 응답주파수 |
35 Hz - 20k Hz +/-3 dB, free space, 1m with grille on, smooth off-axis response. |
| 임피던스 |
6 ohms - easy to drive |
| 감광도 |
84db/1W/1m |
| 권장 앰프 출력 |
Works with a wide range of amplifiers, ideally from 50W/channel. |
| 파워 핸들링 |
200W programme |
| 커넥터 |
Two 4mm gold-plated binding posts for wires or plugs |
| 치수(hxwxd) |
750 x 432 x 400mm |
| 마감재질 |
Cherry, eucalyptus, rosewood. |
| 필요공간 |
LF optimised for use away from hard, reflective surfaces. |
| 스탠드 |
To bring ears level with tweeters. |
| 중량 |
34kg each | |
